I am giving angular dimension to element, and it is more than 180 degree so instead of showing 190 degree it's giving me 170 degree pls let me know if you guys have any way to sort this thing out.
Gelöst! Gehe zur Lösung
Gelöst von Mike.FORM. Gehe zur Lösung
Gelöst von chandrakant_arya. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Hi @chandrakant_arya
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Hey, thanks for the solution @barthbradley but can you give more simple way because the way you showed in the video, I can't understand that, but thanks for the support and prompt reply.
