I have a model with different wall types, and I am now trying to tag them. I selected one, went into Edit Type and gave it a Mark value (EW-1 in this case), thinking that this is what would appear in the wall tag. Then when I went to tag it, I got a question mark instead...
I thought that that was what the Mark value under Identity data was for, but perhaps I am mistaken... Does someone know what changes to the wall type properties I need to make so that every wall tags properly?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Mark is an instance base parameter and is individual to each wall segment. To tag this your tag family should be referencing the Mark parameter. changing the Mark value for the wall will only affect this one wall segment
TypeMark is a type parameter and is applied to all of the walls of this type. Your tag family should point at the Type Mark parameter accessed through the Edit Type button. Changing the value of the Type Mark will affect all of the walls of that type
