Hello All
Thank you for your support
Is there any way to have a triangulation area report in DWG format? as you know diffult is. HTML.
Thanks a lot
BCZ we need to put this data with others' plans and text and sometimes need to edit it.
Export Room/Area to HTML and choose a higher resolution image sizes. Then open Adobe Acrobat > Create PDF from webpage > point to the HTML > you will get a PDF. Link or import it in AutoCAD (it's not a vector PDF but you don't need a vector PDF because you are not supposed to edit the data).
@nima_hakimjavadi wrote:
I got your point but the output data is not editable and No specific scale also. thank you for your time
It is a report. Any editing should be done in Revit prior to exporting the HTML. If you want scale (which is defeating the point of showing triangles with every dimension) then scale the PDF in AutoCAD.
