How to get the sheet list to read revisions automatically?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
tamar88HY2
475 Aufrufe, 6 Antworten
I'm looking to create a sheet list schedule that automatically inputs the revision schedule data per issuance. Is this possible?
Thanks!
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: tamar88HY2
Revit sheet list only shows Current Revision.  If you use pyRevit add-in, you can generate a master Revision Report and save it to HTML or print to PDF.
Nachricht 3 von 7
tamar88HY2
Thanks, but I am looking to get the revision information in the sheet list schedule in Revit. Is there a way for a schedule field to read if a specific sheet was issued under a revision?
Nachricht 4 von 7
Yes.  You can use a Filter.
Nachricht 5 von 7
tamar88HY2
als Antwort auf: ToanDN
Thanks but I'm not sure I am following.. The field 'Current revision' - where does it draw information from?
For example this is my schedule, right now these check boxes require a user to manually check them per revision. How can I make these into smart boxes that read the revisions instead of having to manually input a check mark?
Nachricht 6 von 7
From Sheet Issues/Revisions list.  You select one for the filter and the sheet list only shows sheets under that Revision.
No automatic way.  If you have a lot of sheets, you could add Current Revision field to your schedule, sort by it + Unitemize, so that every sheet under one a Revision will become one row and you can tick just one box for each revission. I recommend to duplicate your sheet list to do this so that your original sheet list needs not to change back and fourth.
Nachricht 7 von 7
tamar88HY2
Thanks ToanDN!
