Hi all
Good Day!!
I need to create a keynote, but it's not showing in Revit 2019. I think the library is missing. how can I get the keynote?
Hi..
Look at that link.. it will show the location of the local keynote file.
%ALLUSERSPROFILE%\Autodesk\<product name and release>\Libraries\<locale and language>
and also learn bit about how keynote file works , and how to create it from the scratch.
by the way, if theres particular parameter which is tagged , and if you don't have that parameter in the project, then then the keynote won't work. I mean sometimes " shared parameters " are used in the keynote, in that case you need to have the shared parameter text file..
best luck.
Are you saying the Keynote file path is missing or incorrect in the Keynote Settings dialog box? If so, use Browse to the load one.
