How to get area boundary different workset options?
1 ANTWORT 1
Nachricht 1 von 2
jeanettephann
211 Aufrufe, 1 Antwort
Hi guys,
I have set up two of the same existing ground floorplan which I'd like to use to create two different area options.
Currently, I've set up the area options in different worksets and turned option A off in one, then option B in the other.
However, I'm getting a message that I have multiple areas in the same enclosed region and its displaying as a redundant area. Anyone know why this is happening and if theres a better way to set up the two areas? Thanks
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: jeanettephann
Use different Area Schemes if you are talking about Areas.  Use different Design Options if you are talking about Rooms.
