Hi, I have a organic shape, see attachments.
I have made a pattern based flat triangle plate and set the width/height to it.
When attaching the pattern based shapes to the organic shape, the triangles don't have the same width/height.
Can I force in Revit to make these trangles the width/height I set in the pattern based family?
Thanks in advance!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
It's all controlled by the divided surface -- not the pattern-based component which is adapting to the pattern created by your divided surface.
