Beams refuse to join over corner columns. They go over non corner columns just fine, but act as if corner columns are cutting them even though beams sit on top of them.
I can fix it manually with shape handles, but it gets tedious with a lot of corners.
Example file attached.
you can try this and see if helps. thanks
here
What about removing that intelligence from the Column Family? Recategorize the Family from Structural Column to Column so the Column won't break your beam joins when it comes in contact with them.
No issues here when beams are still are allowed joining. I placed the structural columns on Level 1, drew the beam s on Level 2, Level, Z justification = Top.
Hi Prvoime,
Thanks for reaching out to the forum. Have you had a chance to look over the suggestions provided by our experts?
Let us know if you require further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
