HOW TO FLATTEN THE EDGES? i have attached the revit file below
14 ANTWORTEN 14
GELÖST
Nachricht 1 von 15
hwangt0412
624 Aufrufe, 14 Antworten
14 ANTWORTEN 14
Nachricht 2 von 15
als Antwort auf: hwangt0412
Post the file here.
...have to see the file, but maybe a void sweep pathed along the edge would clean it up.
Nachricht 3 von 15
hwangt0412
als Antwort auf: barthbradley
i caouldnt attach since the file is too big,is there any other way i can share with you?
Nachricht 4 von 15
Is it splines or arcs?  Spline should be continuous and arcs should be tangential.
Nachricht 5 von 15
hwangt0412
okie,i have attached the file in google drive ,you can have a check~
Nachricht 6 von 15
post the link
Nachricht 7 von 15
hwangt0412
als Antwort auf: ToanDN
i think it is spline~
Nachricht 8 von 15
hwangt0412
Nachricht 9 von 15
hwangt0412
i just realised there are total 3 edges that are not flattened,the other is on the left side~
Nachricht 10 von 15
You need to smooth out those transition from one spline to another of the mass.
Nachricht 11 von 15
hwangt0412
thank you but im not sure how to do that TT
Nachricht 12 von 15
Instead of trying to fix it, I would just redo it. Create the Solid and Void Mass Host from Surfaces of the two existing Masses, close out and use Roof by Face instead of Wall by Face.
Nachricht 13 von 15
hwangt0412
thank you for that,could you please send me this file that you have done?
Nachricht 14 von 15
This help?
Nachricht 15 von 15
hwangt0412
THANK YOU SO MUCH FOR THAT~~~
