after I install Revit 2017 I face a problem which is cell view in schedule . The words and the numbers are overlap, so I can not see any things. Please look to attached file
Change the body text to a larger size - row height is driven by text size -
Before -
After -
Place the schedule on to a sheet to see the results.
Hi @Anonymous
Welcome to the Autodesk community!
Did the solution by @Sahay_R help resolve your issue?
Also, see Modifying Schedules
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
