I'm trying to model a gate door with balusters.
On the left is the 3D and on the Right the elevation. I placed a wall behind it with a lower height. In 3D, the wall can be seen beyond the door whilst in elevations there is a mask I can't find that mask item, in the family editor.
I attached the Revit Project (2023), Thanks in advance. I hope this not a default revit thing
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
Select the opening cut in your family and make it transparant in elevation:
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
thanks @ralphdenhaan , it had to be there, there's always an important setting in that area, Thanks again!
