how to find the walkthrough path distance in revit
3 ANTWORTEN 3
Nachricht 1 von 4
353 Aufrufe, 3 Antworten
hi
i have been trying to measure the path of the revit walkthrough camera but couldnt find with the length of that so  any solution over this would be very helpful.
3 ANTWORTEN 3
Nachricht 2 von 4
Mohamed.Hesham.afifi
als Antwort auf: Anonymous
Hi @Anonymous  ,
Check this it might helps :
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/RevitLT-DocumentPresent/files/GUID-E1665709-05AE-455B-BBB5-C360F36E009D-htm.html
You can use the speed of walkthrough and the elapsed time to get the distance i think
Nachricht 3 von 4
L.Maas
I do not think there is a straightforward method for this. As far as I know it is not exposed through the Revit API.
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 4 von 4
als Antwort auf: Mohamed.Hesham.afifi
is there any formula which you can share across to measure the distance along with the revit walkthrough
