How to fill the space below a stair
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
g.zubini
541 Aufrufe, 5 Antworten
Hello
I want to fill a space below a monolithic stair, between a wall and a floor. Tried with a model in place and join, but it doesn't let me join them.
How can I make it? thanks!
5 ANTWORTEN 5
Nachricht 2 von 6
blank...
als Antwort auf: g.zubini
Just increase the depth of run type.
https://www.youtube.com/watch?v=eJBo1UWz8Q4
Nachricht 3 von 6
ralphdenhaan
als Antwort auf: blank...
You can use this workaround: change your Structural Depth.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 4 von 6
Structural Depth
Nachricht 5 von 6
ralphdenhaan
Well that is 3 times the same solution haha:)
Nachricht 6 von 6
g.zubini
You guys are right. I knew there was an easy way to do it. Thanks a lot!
