Dear Revit users,
Is there a way to extract thumbnail images from Revit Family?
I would like to make "Family Library" connected with lists as a databased file.
So I want to extract all images of my families which will be more than 1000 without taking captures of them one by one.
Any advices will be appreciated!
Yuki
Gelöst! Gehe zur Lösung
Gelöst von cbcarch. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
@ysautodesklover this post is fairly old and I don't know how much of it is still applicable but....
Have a look at this post from 2009.
http://thebuildingcoder.typepad.com/blog/2009/06/rvt-and-rfa-thumbnail-image.html
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Hi @ysautodesklover alias Yuki
Welcome back:)
A more recent post HERE that discusses thumbnail image preview.
@barthbradley I remember you made a post on the thumbnail preview. Can you pls help out Yuki?
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Also, here's a similar idea in the IDEAS forum
Viveka CD
The thumbnail image is associated with a view in the family. The only way I know of to "extract" that Thumbnail image out of Revit, is by saving the associated view as an image (Export). Sounds like the author is aware of that method, but is looking more for a "batch processing" method (e.g. extracting multiple views from multiple families).
Load all families in a project. Create an Assembly for each one. Generate a 3D view for each Assembly. Batch plot or export all assemblies's 3D views to an image format.
It is just a preference. It isolates the element without manual hiding other stuff...
you can try add-ins as well.....
Thank you @ToanDN,
I have been looking for more efficent way cos I have about 600 familes to extract images in lists.
At the last, one of my colleagues wrote code to extract jpg so this problem has been solved!
But this way might be able to use for something other.
Thank you for all comments!!
Thank you @Viveka_CD
I reckon my colleague used this process to make a program for this issue.
I wish that I am skillful to understand programming but not yet now ![]()
Anyway, it helped me to understand how it work.
Yuki
Preview Image Generator will batch process nice previews for your .rfa library.
The next update will also allow high res.png files to be generated also through the process.(1 or 2 months)
https://apps.autodesk.com/RVT/en/Detail/Index?id=951715850256335253&appLang=en&os=Win64
Hi.
Im having same issue of yours, so I gonna try to make simple program like familly image generater.
I think if I get some examples or source code, it is really helpful, because I am noivce at C# programming, too...
May I get some sample codes of yours?
Jin
Preview Image Generator (PIG) now allows you to export high resolution .png images for your families, along with saving them to the .rfa.
