HOW TO EXTRACT CTB FILE FROM REVIT
Message 1 of 10
PLEASE GIVE THE SOLUTION TO EXTRACT THE CTB FILE FROM REVIT EXPORT.
Accepted solutions (4)
Replies (9)
Message 2 of 10
hmunsell
unfortunately there is no way, i know of, to have Revit export a CTB file when exporting to Autocad.
Howard Munsell
Message 3 of 10
Message 4 of 10
ennujozlagam
see this previous thread. thanks
Message 5 of 10
Then please share your idea to extract CTB from Revit.
Message 6 of 10
hmunsell
Ok, i looked into it a little more and there is a way. i have just never had to use it :-).
when you export a DWG from Revit it creates the DWG and a PCP file. that PCP file can be used to create a CTB or STB from Autocad. follow this Video to see more.
Howard Munsell
Message 7 of 10
dbernierJD4CU
That video had nothing to do with ctb files.
Message 8 of 10
RSomppi
Did you read the rest of the post?
Message 9 of 10
ali_dueck
Community Visitor
Community Visitor
This doesnt seem to work with AutoCAD 2024... Any suggestions or insight?
Message 10 of 10
RobRocks
Just to be sure, are you trying to convert a .pcp file generated along with a .dwg export from Revit?
At what point is it failing?
