How to export to dwg with only some color hatches
TomasoCardia
TomasoCardia
Good morning to all,
I'm trying to export to DWG (then I have to plot it in PDF) a Revit project. It are a lot of papers so I need to optimize my processes.
- First all: I need to export only some colors, in this case only the color of the panel (as hatch), how could I do it?
- Second problem is that Revit export the hatch and the line on the same layer, so it is really difficult to separate. Is there a way to separate the hatch to line?
- Third: I have a lot of different panels ( they will be build in different materials) is there a way to do a Legend of different panels?
- And a legend of different Grid type? (As you can see on the image I have different Grids, and currently I insert it by inserting from AutoCAD file)
THANK YOU!!!!
(I hope was clear on my needs 🙂  )
- Create a view showing only the one you want to export
- Override element in view any panels you want to show in color when exported
- Follow the export settings below
TomasoCardia
Thank you very much!
Your helps are as always very useful!
This solution helps me a lot, but is there a way to export in dwg only the colors of the panels? I mean, I need to export the hatch (in a different layers) of every different panels (panel 01 type, panel 02 type...)
The problem of your solution is that I have to underline every single panel, because if I use the categories functions it doesn't make any differences between different panels, but I have give the property to every panels
reassuming:  export a category with their own color (or material) and on DWG different hatch and the rest of categories with it
And, is it possible do this thing for every plans? Or I have to give this information for every plan?
TomasoCardia
At the end I did it with a combination of your help and the helps of Filters of Revit!
