How to export to dwg with image binding
6 ANTWORTEN 6
Nachricht 1 von 7
4906 Aufrufe, 6 Antworten
How do I export to dwg with images binded into one file rather than separate files?
6 ANTWORTEN 6
Nachricht 2 von 7
L.Maas
als Antwort auf: Anonymous
There is no setting to bind images during export. They are exported as linked files.
A solution would be to correct this in Autocad
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 7
als Antwort auf: L.Maas
Hi Enlint,
So I have to double Etransmit?....I checked AutoCad Etransmit setting with bind but I get a folder with all reference files.
Nachricht 4 von 7
You can't even bind raster images in AutoCAD except for using OLE, which is
the entire different mechanism. I don't see how Revit can do it.
What's wrong with external image files?
Nachricht 5 von 7
ipselute
als Antwort auf: ToanDN
How about creating a family in Revit, insert all the logos as OLE in that family, load that family in your project, and then export to Autocad ? Would that be exported as a Autocad block with embedded images ? I know it doesn't work in Titleblock families, but still, perhaps it could work in other types of families.
Is there any tehnical option to create that logos as region masks, i mean like having the logo image mapped as single tile or something?
Nachricht 6 von 7
als Antwort auf: ipselute
Revit have no idea what an OLE is.
Nachricht 7 von 7
colleenc8732L
I need to be able to do this for creating Record Drawings. I need to supply CAD to the client, and any external images must be binded in the CAD drawing.  I have several details that use existing building drawings as images to scale in Revit. It will take too much time to find the images, copy+paste them from paint to turn them into OLEs and scale them. Does anyone have a better solution for this?
