How to export Text, Title lines, and view ports with seperate layers while exporting Revit to CAD?
1 ANTWORT 1
Nachricht 1 von 2
narasimhamurthy8ULAN
254 Aufrufe, 1 Antwort
After exporting Revit to CAD, Revision text and view title lines are in the Viewport layer"Annoplt".
we off the viewport layers while printing pdf since the text and Title lines are also in the same layer they turning off.
What could be the solution for this.
Is there any option to get seperate layers while exporting from Revit to CAD.
1 ANTWORT 1
Nachricht 2 von 2
jacques
als Antwort auf: narasimhamurthy8ULAN
Have you tried with Modify DWG/DXF Export Setup?
It is found at file/export/options/export setups DWG/DXF.
