How to export shadows in DWG files
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2742 Aufrufe, 3 Antworten
Hello everyone, can someone kindly help me? When I export an elevations with shadows from revit to a dwg files how can I do to have in autocad a layer of that? Because it export with all layers just the elevations without that. At the export moment the shadows are switched on. Thank you very much
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
You can't. But you can export shadows to DWF or Image and underlay/overlay in AutoCAD Drawing.
Nachricht 3 von 4
als Antwort auf: barthbradley
thanks for answering, i did it but really does not exist an automatic command to have a layer (with polyline or hatch) of the shadows or something like that?
Nachricht 4 von 4
alberto-secondi
Correct, I don't think there is a way to do this automatically. However, this may help overlaying the shadows to the vector. Revit to DWG + Revit to PDF and then combine the two (remember to check the raster images option)
At least it will give you an insertion point to work with.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
