How to export revit to cad - layers
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Mohammadbutt-ATC
331 Aufrufe, 2 Antworten
Hi
I need to export the sheet from Revit to cad in the same layers of Revit because I want to print the sheet from cad the same as I print it in Revit.
For example, I have
1- setting out plan with black walls and text in blue,
2-equipment plan with grey walls and tags in blue so when I print out from Revit it gives me the same settings of layer colors but when I export in cad it gives me the walls color in different color text in yellow etc...
i need to export in cad all layers as it is in Revit so if I need I can print the layout the same as I can print in Revit i don't want to waste time changing layer colors in cad
2 ANTWORTEN 2
Nachricht 2 von 3
Tommy_S
als Antwort auf: Mohammadbutt-ATC
In the dwg export setup settings change colors to the option "specified in view"
Nachricht 3 von 3
Thank you,  you solved my issue 100% correctly.
