Hello! I'm completely new to revit and mostly work in CAD/Rhino 7, but I recently I was given a simple site plan file with that contains a map, and simple building heights in the form of the blocks. The site plan looks like it was made in CAD and then imported to Revit. I was wondering how can I find that CAD file and simply take it, or more accurately export this very Revit model into CAD with all the building heights. I tried exporting a shadow study but it only exported as a flat, 2d CAD file. But when I open the Revit file in Enscape, I see that the surrounding buildings were built using simple masses in 3D, I just want that information in CAD. Thank you!
Make sure you turn on the Mass Category under Visibility and Graphics Overrides of the 3D View you are exporting from - even if Show Mass Form and Floors is turned on in that View
@jlifeng wrote:when I open the Revit file in Enscape, I see that the surrounding buildings were built using simple masses in 3D, I just want that information in CAD.
Can you clarify exactly what you want to Export FROM REVIT to DWG. Saying that you want to Export the information you SEE in Enscape does not answer the question.
