How to export MEP Fabrication pipes as non-mesh (surface/solid) geometry?
2 ANTWORTEN 2
Nachricht 1 von 3
jeroenvanlithWWCBG
295 Aufrufe, 2 Antworten
Hi there,
I'm trying to export a Revit model to non-mesh (so solids, surfaces, etc) geometry. I use the DWG export and set the "export solids as" to "ACIS solids". Native Revit pipes get correctly exported as solids, whereas the pipes from MEP Fabrication dataset get exported as block instances with Mesh geometry. Does anyone know how to get the non-mesh representation (surface or solid) from the MEP Fabrications parts?
Thanks!
Jeroen
Beschriftungen (4)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: jeroenvanlithWWCBG
Nachricht 3 von 3
Thanks barthbradly! But I am trying to avoid creating the mesh in the first place, when I'm exporting to DWG.
