How to export material properties from Revit to IFC
2 ANTWORTEN 2
Nachricht 1 von 3
998 Aufrufe, 2 Antworten
I'm trying to export material properties from revit to IFC. I know that I have to complete the "Default User Defined Parameter Sets" but I don't know how to do this. Is it possible to export the material mechanical properties and also the material keynote? Any suggestion?
Thanks a lot
2 ANTWORTEN 2
Nachricht 2 von 3
L.Maas
als Antwort auf: Anonymous
Not sure if it will work, but when exporting try to set "Export  Revit property sets"
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 3
als Antwort auf: L.Maas
It doesn't work. When I set "Export Revit property sets", it exports the material, but it doesn't export the material properties.
