How to Export Heating and Cooling Loads Report to Excel?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
jshubin
4865 Aufrufe, 4 Antworten
How do I export a Heating and Cooling Loads Report to Excel?
Revit 2016.
Thanks.
4 ANTWORTEN 4
Nachricht 2 von 5
yurikim
als Antwort auf: jshubin
There is no direct way to export this report, but you will be able to select all items, and paste them in Excel.
Hope this helps.
Yuri Kim
Product Support Specialist, AEC
Nachricht 3 von 5
Martin-Hawley
you can locate the HTM file here:
file:///C:/Users/YourUserName/AppData/Local/Temp
You can then open the HTM file using Excel and then Save as.
Martin Hawley
Tags (1)
Nachricht 4 von 5
als Antwort auf: yurikim
Simply go on your heat load report in Revit> Press 'File' > 'Print' > 'Print to PDF' and save at your desired location. Done!
Nachricht 5 von 5
AS4488
als Antwort auf: Martin-Hawley
But how we get that files there were many files there.. how we know file name???
