How to export as fbx and group by material?
choimozarts
choimozarts
When importing into 3dsmax there is an option to combine by material, is there a way write an fbx directly out of revit with attributes based on materials so i dont have to go into 3dsmax just to re-export? Thankyou!
I believe there an Add-in that can do this.  Check the Store.
RDAOU
@choimozarts
You do not need 3dsmax.. If the material has been assigned to each object/element in Revit, exporting to FBX will exports the material parameter as well... Not sure what you mean by grouping though
Samuel.Arsenault-Brassard
vimaec.com can do this, it will also rebuild all the ridiculous meshes in a proper manner so that triangle counts go down dramatically, usually it's 1/3 of the traditional FBX triangle count.
You can also group by combination of workset, model link, category, etc.
SamuelArsenaultBrassard_0-1657219919326.png\
An example of importing by Category and Material
Just importing by material
Disclaimer: I work for this company. I also wish I had access to these tools 10 year ago 😅
