how to export a adsk file from revit to civil3D ?
chengj
Message 1 of 10
chengj
I want to  export a “adsk” file from a revit  to the civil3d. in my opinion ,when import the “adsk” file to the civil 3d, the coordinate of the set point should be the same to the one of the survey point or the project point ,but it seems not . (As Show in the following pictures) every time I must to move the site to the correct location manually. What is the problem? How can I import the revit model to the civil 3d thought the adsk file in a more automatically way ?
                                          A view in the revit (linking the civil 3D file)
        6 buildings buillt in the revit
        Export a adsk file from the revit
Replies (9)
Message 2 of 10
chengj
Coordinate of the survey point and the project point
                                  The civil 3d files.
                                          Import the adsk file to the civil 3D
                               The buildings are not in the correct locations
Thanks for you help.
Message 3 of 10
zijie.chen
HI, chengj
You can try according to the following steps:
  • Install the Civil 3D and Revit Extension "SHARED_REFERENCE"
  • In Civil 3D select an easy to identify point and define it as shared reference point
  • In Revit import the shared reference point as XML file and put it to the same location as in Civil 3D
  • In Revit make sure that the Project Basepoint and the defined Survey Point are at the same location
  • Export the construction to ADSK format
  • Import the construction in Civil 3D
Another workaround can be exporting the file to DWG (AutoCAD) using Shared Coordinates and then importing the DWG file to Civil 3D.
__________________________________________________________________________________
If my post answers your question, please click the " Accept as Solution" button. This helps everyone find answers more quickly!
Zijie Chen
Message 4 of 10
chengj
Thank you for you reply.But I can't follow your steps very well .Take the first step for example ,I relly can"t fine the  Revit Extension "SHARED_REFERENCE". where  could I get ? And in fact , last time in another project , We have export a .adsk file from revit to civil3D sucesfully without any problems .
any finally, I try to export the revit file to cad, but I fine the (0,0,0) point in CAD is in the same location of .adsk file.in another word, it is not in the survey point or base point .
however,it is not easy to express though the words . So I upload my error files(revit ,civil 3D and adsk file). Can you hepl me to see what is the problem.
Thank you for your reading.
Spoiler
Message 5 of 10
zijie.chen
HI chengj:
This tool is available by the Autodesk subscription centre,you can refer to this link (https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles... to download the tool.
and ,if your software is version 2017, so far, there may be no release of the tool (https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/discussion/t5/AutoCAD-C... ).
If you want to know how to use the tool, you can refer to the following links:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/05f...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/video/youtube/watch-v-5l1kv...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/video/youtube/watch-v-di7zU...
Zijie Chen
Message 6 of 10
zijie.chen
if  you cannot open the first link ,please use this one
and ,I will use your file to test, if i find the reason , i will tell you at the first time
Zijie Chen
Message 7 of 10
chengj
Spoiler
Spoiler
Smiley LOLThank you very much ! Yes, my vesion of the auto softs are 2017,maybe this is the problem. however,I have downloaded the relevant video . the complex coordinate system of revit always confuzed me .
Thanks .
Message 8 of 10
zijie.chen
Hi chengj,
Thank you for your question, and i test for your file, i am sorry to tell you that i cannot find the reason.And i  searched an article named"An ADSK file exported from Revit and imported in Civil 3D as Building Site has a wrong location"(i have email to you), and it suggests that you should Install the Civil 3D and Revit Extension "SHARED_REFERENCE" to solve this problem.
hope my information can help you.
If my post answers your question, please click the " Accept as Solution" button. This helps everyone find answers more quickly! or you can tell me ,and let me close it.
thank you!
Zijie Chen
Message 9 of 10
chengj
ok,thank you all the same.
Message 10 of 10
zijie.chen
thank you!
Zijie Chen
