How to export 2D dwg files from 3D Revit views without getting rough and not tidy lines?
ale_jablonski
ale_jablonski
Hi guys,
Whenever I drag a 3D view to a sheet on revit and export it to dwg (aiming a 2D dwg file), the results are a bit off, like this:
Because If we export it straight from a 3D view, it creates a perfect 3D dwg on AutoCAD 3D (which is not what I want, but it's perfect).
Is that any solution for that?
Thanks!
Use a larger scale, even 1:1 for the view.
ale_jablonski
@ToanDN Thanks for your reply.
Tried that as your suggestion and didn't help. However, I tried to set as wireframe and it works very well (what helps alot), but Hidden Line mode doesn't though (because tidying up the wireframe one on AutoCad becomes tricky sometimes [in order to make it not transparente/wireframe]).
You can export a 3d view directly to 3d DWG, then run FLATSHOT to create 2D DWG.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Or, run DXBOUT to create a DXB file, then DXBIN to bring it in and you will have 2D DWG showing 3D linework.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
