How to Edit Family ID Picture
9 ANTWORTEN 9
Nachricht 1 von 10
902 Aufrufe, 9 Antworten
How would I change the picture shown in Revit Project for a family I created, under the Properties Box? (Shown Below, Highlighted)revit family picture.PNG
9 ANTWORTEN 9
Nachricht 2 von 10
Sahay_R
als Antwort auf: Anonymous
What is it that you would want to change about the picture?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 10
als Antwort auf: Sahay_R
Right now the cabinet is shown upside-down I would like a front view or an up-right 3D view of the cabinet to be shown.
Nachricht 4 von 10
Sahay_R
Revit displays a 3D view of the object in the position in which it was modeled. If you want the view to change. the object will need to be rotated accordingly.
Rina Sahay
Nachricht 5 von 10
Wouldn't the cabinet be inserted upside-down if I did that?
Nachricht 6 von 10
Sahay_R
Does the cabinet behave correctly when inserted into the Project?
Is the family a hosted family - ie wall, face, or ceiling?
Finally, can you share the family?
Rina Sahay
Nachricht 7 von 10
Does the cabinet behave correctly when inserted into the Project? -yes
Is the family a hosted family - ie wall, face, or ceiling? -Face
Finally, can you share the family? See Attachment
Nachricht 8 von 10
Sahay_R
Face based families doe show up with weird 3D views! Here is a quick fix -
1) Start a New Family
2) Use the Casework - Wall Based template
3) Load your original family into the new family
4) Associate nested family's parameters with host family.
You have now converted a face based family to wall based. The 3D view in properties should also show up correctly.
Rina Sahay
Nachricht 9 von 10
Our drafters don't want it wall based, they want it to be face based.
Nachricht 10 von 10
Sahay_R
As far as casework goes, wall based behaves the same way as face based. Or you could go with generic model, and snap it in place. The result will be the same.
Face based families will always show the object lying on its back. We have face based toilets in our library that show up lying on their backs. Strange but true.
Rina Sahay
