how to duplicate the view range setting
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
m5ntc33612
518 Aufrufe, 4 Antworten
Hi, is it possible to move the settings of view range to another view?
I made several elevator sections. However, since there are many elevators, I realized that I had to set the view range one by one when I made the sheets. It will take a long time to change the settings of the view range one by one, and there will be many human errors I want to apply the same view range setting on a floor basis, is there any way?
For example... If the VIEW RANGE of elevator A on the 2th floor is 1400/900/-1800/-1800, I would like to set the same VIEW RANGE for elevator B on the same floor.
4 ANTWORTEN 4
Nachricht 2 von 5
ralphdenhaan
als Antwort auf: m5ntc33612
You can make a View template to use the same View Range for other views.
Or create a simple Dynamo Tool to copy them. But I don't know if you are familiair with the use of Dynamo?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 5
m5ntc33612
als Antwort auf: ralphdenhaan
thank you. Then if I delete the VIEW TEMPLATES I applied, will all settings be turned off? DYNAMO still lacks proficiency, so I think I should try this function.
Nachricht 4 von 5
ralphdenhaan
When you remove the View templates, the View Range will stay. So all your settings stay the same.
Nachricht 5 von 5
Uncheck view range in the main template, check only view range in the temporary template, apply the temporary template to the view, then reapply the main template to the view.
Another option is not using view range, but use a plan region and copy paste it to other views.
