How to divide schedule by FAR and NONFAR?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
gnarkill283
442 Aufrufe, 1 Antwort
I made an area plan with all non far areas named "NON FAR..." Is it possible to group the far areas and the non far areas separately in one schedule by name? Doesn't seem to be possible under sorting/grouping. When I click on an area, there aren't a lot of parameters by default - will I have to add one which is associated with a field that I need to add to the schedule? How does one do that? Thanks
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: gnarkill283
All the areas, FAR and NON FAR, should be under the same Area Plans and in the same schedule. Use a parameter such as Comments to enter FAR and NON FAR, or create a Y/N parameter checkbox, up to you. Then you can use sorting/grouping/filtering to separate them based on the parameter above.
