How to divide a Revit Model into disciplines (Architectural, Structural, Mechanical) to import into Navisworks?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
218563263
329 Aufrufe, 1 Antwort
I'm looking at learning how to separate Architectural, Structural and Mechanical from a single Revit model as individual files. (E.g Architectural.rvt, Structural.rvt and Mechanical.rvt). To then combine in Navisworks.
I'm using Revit 2021 and does the "advanced_sample_project" all work together if combined in Navisworks?
https://help.autodesk.com/view/RVT/2021/ENU/?guid=GUID-61EF2F22-3A1F-4317-B925-1E85F138BE88
1 ANTWORT 1
Nachricht 2 von 2
RSomppi
als Antwort auf: 218563263
It sounds like you are talking about visibility settings rather than separating into individual Revit models.
Make 3D views for each export and set the visibility accordingly.
