how to display area in schedules both in sq.m and sq.ft
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
basma_salman
2121 Aufrufe, 3 Antworten
i'm trying to show area in two columns in area schedules, one with sq.ft and the other column in sq.m, i tried to make calculated parameter but i think there is something wrong in the formulaCapture1.PNG
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: basma_salman
Format Tab. Field Format. Change Units.
Nachricht 3 von 4
basma_salman
als Antwort auf: barthbradley
i need two columns one sq.m and the other is sq.ft, so i should convert the area in sq.m by multiplying the area in sq.m*10.77= area in sq.ft, but when i use the calculated parameter the result is wrong if i have area 132.8 sq.m*10.77=1,430.256 sq.ft not like in the image i posted
Nachricht 4 von 4
basma_salman
oooh so i dont need to make a formula???
