Hi all,
How can I differentiate objects on the same mass?
Here, on a example, I put a mullion and panel (both directly inside the mass, no as curtain system), I like to differentiate it (to see the mullion or panel when I want).
Is there a method to do it? Something like "create a group" or similar?
Thank you
not only scheduling.. I separated yet in this way.. I need to separate it to model on 3d views for example.. (hide, unhide objects)
If you classified them by criteria I listed earlier then you can create View Filter to control their graphic and visibility, including hide/show, change color, transparency, etc...
Thank you very much Toan, at the end I Solved it in an other way.. With Filter (I didn't know them)
