I coworker told me about "parametric family" for Revit. I am familiar with parametric models, but not in the Revit context.
I found the model attached in one of the websites for 3D assets:
Free Heating Radiator in GrabCAD
Is it parametric? How can we tell?
TIA,
-Ramon F Herrera
JFK Numbers
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
@ToanDN wrote:
By opening it and look at the family properties. Or insert it in a project and look at the instance/type properties.
This particular family is not parametric. The geometry was imported from a CAD file. It is purely for visualizations.
Bonus question: When they say "parametric", how many parameters are possible? I would imagine at least 3 factors: for X, Y and Z, used to grow/shrink the base model.
TIA,
-Ramon
JFK Numbers
Parameters can be any kind of information, some of which might be used to change the physical size of the family. You can also tell if a family is parametric when it is loaded into a Revit project. Does it have multiple types? If it does then usually that means it represents more than one configuration of that real life element. For example, a single panel door can be purchased in several sizes but a parametric Revit family can provide all the sizes with one family. A separate family can provide a different configuration like a double door or a very complicated version could provide both single and double doors. Revit content design seeks a balance between simplicity and capabilities...some succeed better than others.
Steve Stafford
Here's a parametric one for you:
https://www.revitcity.com/downloads.php?action=view&object_id=17068
