How to detach from central for only select worksets?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Sleepingfish_Kuo
164 Aufrufe, 3 Antworten
I've select only the worksets I want to keep, but the detach file still keeps anything.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Sleepingfish_Kuo
They are two different settings and have nothing to do with each other.
Nachricht 3 von 4
Sleepingfish_Kuo
als Antwort auf: ToanDN
So I need to do it manually like this?
1. detach with workset keeps.
2. delete all things in other workset.
3. save.
4. create detach file again (throw the workset) and save.
Nachricht 4 von 4
No. Here is what you do:
- close the file
- open it detached
- delete worksets (not elements) you do not want
- revit will give you two options, pick the obvious one
- save the file
