How to designate an additional Attached Detail Group
cbt990
cbt990
When I load a building module into my project as a group, it asks if I want to include attached detail groups. The only available detail group to display is "Level 1". That is my floorplan with all the dimensions and constraints on it. However, I have another floorplan in the model with wall, window, and door tags. Those are the details that i am really interested in attaching when loading as a group. How do I create a new group of those annotations that I can toggle on in my central model?
Thank you
Revit is amazing
Replies (8)
Thank you
You can create an attached detail group of tags and another attached detail group of dimension/notes to a model group by this method:
- add tags and dims/notes to model elements
- select the models elements and tags, create group. that would create a model group and an attached detail group of tags
- select the model group you just created and the dims/notes and create group, that would create another attached detail group including the dims/notes
- now you can choose either or both attached detail groups to attach to the model group.
cbt990
The tags are information that I need to show in my plans. The dimensions in each group are for reference and verification only. If I show the entire group, the plans are unreadable because each module has its own dimension strings.
Revit is amazing
cbt990
Thank you for the suggestion. I can't group the tags:
Revit is amazing
You cannot just group the tags by themselves.  You need to select the model elements AND their tags and group to create the attached detail group #1.  Then select the model group you just created AND the dims/notes and group to create the attached detail group #2.
cbt990
Last copy of group deleted whenever I finish adding the tags to the group?
Revit is amazing
cbt990
I have tried to get this to work a few different ways. I managed to create a detail group in the project, but when i try to load the detail group after inserting the project as a group into another project and I enable attached details, it shows me everything BUT the details in the group.
Revit is amazing
cbt990
It says "last copy of group deleted. group type removed from project" when i try to finish creating the detail group. I add the model elements to be tagged into their own model group. Then i create a new detail group and add the tags:
When I hit finish:
Revit is amazing
