How to design dome ceiling in revit architecture
3 ANTWORTEN 3
Nachricht 1 von 4
P93mahapatra
1748 Aufrufe, 3 Antworten
How can i design dome ceiling in Revit architecture like in this image. Which method is convenient. This I want to design inside of the house.
Tags (2)
Beschriftungen (1)
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: P93mahapatra
You can create a dome mass and create wall by face and pick the mass form surface.
Or you can create an in place ceiling and model a revolve to create the dome.
Nachricht 3 von 4
Create a single parametric panel by Sweep Blend tool -> Load into another family as nested family for polar array to control how many element and the angle you want -> Load into projects.
You can use Generic model template family to do it.
Nachricht 4 von 4
3D Beams + Pick Lines method to pick Mass edges + Radial Array.
