How to delete items under Properties ?
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
emersongonzalez1999
1911 Aufrufe, 8 Antworten
So I created items under Properties, either by remaining or duplicating. But how can I delete the items created? In this case I rename a monolithic stair as shown in the attachment. Please let me know how can I delete these Items. Thanks
8 ANTWORTEN 8
Nachricht 2 von 9
Purge Unused.
Manage tab.
Nachricht 3 von 9
But that only hides them is there a way to delete them?
Nachricht 4 von 9
als Antwort auf: emersongonzalez1999
Nachricht 5 von 9
Nachricht 6 von 9
Ah I see and for example, I rename some items under the properties how can I reset the setting for Properties so it contains the original names when you started the project.
Nachricht 7 von 9
Undo or rename them back.
Nachricht 8 von 9
emersongonzalez1999
als Antwort auf: ToanDN
Thanks I'll try to be more careful next time
Nachricht 9 von 9
If you delete a Default Type mistakenly, don't fret. You can always use Transfer Project Standards at any time to transfer a Default Type from a New Project.
