How to cut/section model in place
arifterbaik14
arifterbaik14
how to cut model in place, i want to cut my model in section, but it doesn't cut in section view
The gray object is the model in place.
RDAOU
@arifterbaik14
Edit in-place and check the option "Enable Cutting in views"
Otherwise change its category. It needs to be of a category which is cuttable ...example: Generic Model, Specialty Equipment...etc Check the following link for a better undertanding of cuttable/non-cuttable categories...there is a Youtube link therein too Some families are not cut in section view in Revit
arifterbaik14
Thanks for your feedback. This works in the family model, but how do I cut if it model in place?
RDAOU
@arifterbaik14
You are using Entourage Category which is not cuttable
Please read my previous reply. You need to use a category which is cuttable or that give access to the option Enable cutting in views...Edit the in place family and change category
arifterbaik14
I’m really grateful for your assistance, sir. Your guidance helped me a lot. May happiness always be with you.
