How to Cut a Wall from a Mass Window
16 ANTWORTEN 16
Nachricht 1 von 17
2099 Aufrufe, 16 Antworten
Hello!
I am having difficulty cutting a wall from the face of a mass. I have windows that are generic model pattern based extrusions, however Revit will not let me cut the window out from the wall.
Any help would be greatly appreciated :leicht_lächelndes_Gesicht:
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: Anonymous
Add a void in the window family , check cut with void when loaded, then use cut geometry in project to cut the wall with the window.
Nachricht 3 von 17
Can you post the file?
Nachricht 4 von 17
als Antwort auf: barthbradley
Yes!
Here is the file of the mass:
And the second one is the windows that I am using:
Nachricht 5 von 17
Yep!
Nachricht 6 von 17
Sorry for the spam, files wont send for some reason
Nachricht 7 von 17
Arrgh! I've been having similar issues lately.  Bummer.
@Viveka_CD: would you know why and what a workaround is?
Nachricht 8 von 17
ZIP them and send the zip file.
Nachricht 9 von 17
als Antwort auf: ToanDN
I did that, but still the wall refuses to cut >.<
Nachricht 10 von 17
Are you actually replacing divided surface solid panels in with glazing panels.   If so, I don't see how it could not be "cutting" (e.g.Transparent) .  Unless your panel material isn't transparent. Have you checked that the correct material is applied?
Nachricht 11 von 17
I don't understand what you mean, my apologies. I have attached the file for the pattern based divided surface panels that I am using.
Nachricht 12 von 17
This doesn't help me. Send the Project file.
...I do strongly recommend that you associate the Mullion and Glass Geometry's "Material" Property to Material Parameters in the Family Types dialog box.
Nachricht 13 von 17
My apologies! :verwirrtes_Gesicht:
Nachricht 14 von 17
I don't see any issues with glass transparency.
Nachricht 15 von 17
If you load it into a project and add a wall by faces the wall does not cut out the window spaces.
Nachricht 16 von 17
Of course it won't. You need separate surfaces for the walls.
Nachricht 17 von 17
Thank you!
How would I go about doing that?
Thank you!
