How to cut a sloped section it is parallel with a surface in PROJECT ?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
2448 Aufrufe, 2 Antworten
Hi, i have a problem that is about "How to cut a section it is parallel with a surface in PROJECT ?". Revit can do that?
for example, here has a inverted triangle, i can cut like the blue line, but it cannot measure the precise angle (60) in this section. That why i must cut a sloped section like the red line to get the value. i tried to use the work plan but it not work in this case.
many thank
2 ANTWORTEN 2
Nachricht 2 von 3
semko_dm
als Antwort auf: Anonymous
Hi!
First of all, if you know the angle you can rotate section like any other element in Revit.
Also, sections can snap to reference planes, so you can draw a reference plane first, and then a section view.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Nachricht 3 von 3
on  placement, the section will snap to the face. If you want to rotate an existing section, don't forget about the value of placing ("Place") the "Center of Rotation" (located on Option Bar).
