I need to put a small roof on another roof like on the picture. I was able to cut the bigger roof but I dont know how to cut the extent of the smaller roof that goes inside.
Gelöst! Gehe zur Lösung
Gelöst von mauricio_mssf. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
If you are able to create the two roofs separately - and join one to the other using the Join Roof tool - then you can use the Dormer Opening tool to create the opening in the lower roof.
,,,or you could do it all in one Roof Sketch using Slope Arrows.
....with two Roofs and Dormer Opening:
How to cut a roof on a roof See the Screencast how I do this union.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
Mauricio Santos Filho Arquiteto | BIM Manager
