Hi everyone.
I have been trying to cut a regular architectural vertical column with some incline in the top but haven't succeed yet.
I have tried to cut the top to a reference plane as I have seen in some tutorials but it doesn't work.
I have also tried to attach the top to a sloped beam on top of the column but it only makes contact keeping the top side horizontal.
Can somebody help me?
Thanks so much.
Gelöst! Gehe zur Lösung
Gelöst von victor_enrich. Gehe zur Lösung
Create a void extrusion in the family in an elevation view and constrain the sketch to the ref planes.
Lock the end point of the sketch line to the upper level and add an angled dimension parameter to control the angle.
The 100 dimension is also locked, you want the extrusion to extend above the column so that the angle parameter can handle a 0deg value.
Why don't you just Join Geometry? Join Geometry removes volume at the union.
I assume he switched the columns to structural columns and used the coping tool which was mentioned previously by both myself and @mhiserZFHXS
@Mike.FORM wrote:I assume he switched the columns to structural columns and used the coping tool which was mentioned previously by both myself and @mhiserZFHXS
Am I "he"?
If so, I just used Join Geometry tool and joined the Columns to a Roof in the screenshot example.
Is it a Structural Column? If so, and it isn't cutting back to a Ref. Plane, it's probably because the Material For Model Behavior is set to Concrete. Set to something else.
Attach columns (arch or struct) to a ref plane and set Maximum Intersection.
