How to cut a ceiling insulation in bevel?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
558 Aufrufe, 3 Antworten
Hello AUTODESK COMMUNITY,
I'm a student in Denmark, studying on Erhvervs- Akademiet Lillebælt, and I ran into a problem no one seems to be able to solve for me.
Does anyone know if it's possible to cut the ceiling insulation in bevel, so it does not pierce through the roof? (Please see attached picture below)
Best Regards,
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Anonymous
You can cut the "roof" using a void model in-place.
- Model your desired roof.
- then go to ( Architecture -- Build -- "under component" you'll find Model In-Place
- after choosing the category and the name, go to Create -- Forms -- Void Forms "and chose your preferred way of modeling " I would use sweep for your groove".
- after your done with modeling your form, and before finishing the in-place editor make sure to cut the geometries "the roof and the model".
- click finish.
Good luck.
Nachricht 3 von 4
Thank you so much!
Nachricht 4 von 4
I've recorded this video for you:
http://autode.sk/2Dqu4wg
I hope that is helping you.
If you think that my comment answered your question, you can mark it as an accepted solution so other people can benefit from the same solutions.
Good luck!
