How to create that pattern in revit ?
16 ANTWORTEN 16
GELÖST
Nachricht 1 von 17
alex.motion
7655 Aufrufe, 16 Antworten
Hi !
I tried from materials but has nothing like that in templates , tried with linestyles but how do I create 1 dashed and one whole line pattern ?
concrete
16 ANTWORTEN 16
Nachricht 2 von 17
als Antwort auf: alex.motion
Download pyRevit and create tge pattern using its Pattern maker tool in Revit.
Nachricht 3 von 17
alex.motion
als Antwort auf: ToanDN
It creates patterns but only fill patterns , when trying to apply pat file to cut plan it says no drafting patterns found
does that tool pyrevit creates only fill patterns ?
Nachricht 4 von 17
Got AutoCAD? Looks like AutoCAD's  "Brass" hatch. If so, you could open the acad.pat file with Note Pad, copy the "Brass" hatch definition in it to a separate Note Pad file and save it as a .pat file.  You could then use it to create a custom hatch in Revit.
"Brass" in Revit:
Nachricht 5 von 17
alex.motion
als Antwort auf: barthbradley
No I don't use Autocad. Can't believe that hatch is so irresponsibly complicated.
Just wonder what features devs are thinking for revit 2022 while creating
new hatch needs autocad and third party plugins.
Nachricht 6 von 17
Pattycake_Kyle
Pattycake has a bunch of free pre-built PAT files in our library that would work for you... Or you could just customize and make your own.
Our draw in web is free for up to 3 lines, which you can make this one with just 2. Nothing to download or install :lächelndes_Gesicht_mit_Sonnenbrille:
https://pattycake.io/official/pat/Yl3lJmwOwb4
Concrete Hatch with 2 linesConcrete Hatch with 2 lines
Happy pattern making! :geburtstagskuchen:
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
Nachricht 7 von 17
Why don't you just ask for it?
Download the attached RVT and use Transfer Project Standards to transfer the pattern to your Project.
Nachricht 8 von 17
Nachricht 9 von 17
alex.motion
Hope one of those solutions will work , it treats some patterns as only fill patterns and denies to be used in cut plans.. will check it tomorow.
As for why im not just asking for pat file directly , because im more incline towards solving a problem in general, rather than asking for one pat file each time when different custom one needed.
Thank you for help.
Nachricht 10 von 17
@alex.motion wrote:
...it treats some patterns as only fill patterns and denies to be used in cut plans.
I think what you are talking about is Model Patterns and Drafting Patterns. Two different animals.  You ought read up on them. It's important to understand the distinctions between the two.
Nachricht 11 von 17
alex.motion
I understand they are 2 different ones , one is treated in model units scale , second is treated as for paper scale, overaly It doesnt matter , pattern is pattern its main goal is to array and  repeate lines.
Let it be drafting pattern.. Me understanding and reading manuals about those 2  patterns doesnt help the fact that revit has to go for autocad or plugins to create simple hatches, i dont even know above solutions will work for plans or no, will see tomorow.
Nachricht 12 von 17
@alex.motion wrote:
Me understanding drafting pattern doesnt help the fact that revit has to go for autocad or plugins to create patterns
You can write your own hatch pattern definitions as well, using any text editor, such as Note Pad.
Here's one (units are in inches):
*My Hatch Pattern
0, 0,0, 0,.25
0, 0,.125, 0,.25, .125,-.0625
Copy it to a Note Pad file, save it as a .pat file and use it to create a custom Revit DRAFTING Hatch Pattern.  Know how? If so, test it.  You'll see.
Here's one tutorial I found for you on-line that describes the fundamentals of how to write your own Hatch Patterns. There are others. Just Google search for them.
https://www.afralisp.net/autocad/tutorials/creating-hatch-patterns.php
Nachricht 13 von 17
alex.motion
ok , thank you for help, lot things to try tomorrow.
Nachricht 14 von 17
alex.motion
als Antwort auf: Pattycake_Kyle
I can't register to that site, what is wrong with that ?
Nachricht 15 von 17
Pattycake_Kyle
@alex.motion sorry to hear! Make sure you are on Chrome, Firefox, or Microsoft Edge. Internet Explorer isn't supported for a lot of the coding on the site and things break.
Otherwise, can give more detail on what's going on? Feel free to also shoot videos or screenshots to hi@pattycake.io as well. We can help troubleshoot more.
www.pattycake.io
Nachricht 16 von 17
alex.motion
It's more responsive now , I don't know what was wrong with that hours ago.
Thanks again ! That website is amazing.
Nachricht 17 von 17
Pattycake_Kyle
Great to hear! :Gesicht,_das_eine_Umarmung_gibt: Of course, please reach out if anything funky happens again.
Happy Pattycaking!:geburtstagskuchen::geburtstagskuchen:
www.pattycake.io
