How to create tag with warning?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
768 Aufrufe, 6 Antworten
Hi
We are tagging a railing to obtain its length but the problem encountering is that we would like a custom message to display base upon railing being a certain length. Controlled via 'if condition, true , false' statement.
The tag is set set as and we have a label reading length working but can't figure out how to get the length to speak to the preset warning message.
Any ideas how to go about this
6 ANTWORTEN 6
Nachricht 2 von 7
L.Maas
als Antwort auf: Anonymous
A tag just reads parameter values from the object it is connected to. So it can not be used to generate a awarning message.
I am not sure how and where you would generate and show this warning message.
A more common solution would be to create a schedule for this. In the schedule you can put the lengths. If needed you can use conditional formatting so that a length value will be highlighted with a colour when certain conditions are met (e.g length longer than certain value)
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 7
You might be able to get there through a Calculated Value in the Tag.
Nachricht 4 von 7
bin
As mentioned by @barthbradley , something like this...
Nachricht 5 von 7
als Antwort auf: bin
Yes this what i am trying to achieve!!
I can't figure out how to get the length label linked someway to a custom parameter.
How did you go about setting up the tag to state too short or too long?
Nachricht 6 von 7
Got the railing length parameter to speak to the custom parameter (travel distance) so that this would talk to the visibility parameters for the warning message on/off.  But in project environment the length does not trigger to warning text to appear or disappear.
Nachricht 7 von 7
bin
Visibility parameter won't work, but here is a workaround:
In your tag, create another label and add a calculated parameter to it.
Put in the formula: if(Length > 10000 mm, "Too Long....", " ") something like this, make sure there is a space between the two "
Here's the result:
