How to create seamless (Curtain Wall) insulation panel with mullions
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
kamanlam
462 Aufrufe, 5 Antworten
Hi all,
novice Revit user here needing your tips. How can one create a curtain wall - with insulation panel as facade element and vertical mullions - that fills the 'gap' behind the mullion with insulation too? I tried creating one basic insulation wall and one 'empty' curtain wall only with mullion, to see which I could join the two. But Revit won't let me place a wall on top of another.
Million thanks for your help!
Tags (1)
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: kamanlam
Sounds like you want to do multi-loop mullion profiles which can now be done in 2025.
Is this what you are after:
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-3D7247D9-BC7E-4E2A-A604-3068CDFC4861
Nachricht 3 von 6
You can sandwich wall types together in Revit.
...and FWIW, you can replace Curtain Wall Panels with Basic Wall Types.
Nachricht 4 von 6
You can certainly place a wall over a curtain wall.  Set the curtain type to NOT automatically embedded.
Nachricht 5 von 6
kamanlam
als Antwort auf: barthbradley
thank you Barth Bradley :leicht_lächelndes_Gesicht: it isn't what i'm after but thanks for pointing me to this interesting new feature. finally updated revit to 2025 thanks to your push
Nachricht 6 von 6
kamanlam
als Antwort auf: ToanDN
Thanks so much ToanDN! this solves directly my problem :leicht_lächelndes_Gesicht: i wonder tho if there might be a better way to do this though to avoid double counting or so
