How to create Railing for this stair
6 ANTWORTEN 6
Nachricht 1 von 7
340 Aufrufe, 6 Antworten
Dear all,
I am a beginner in Revit, and I need to learn how to create a railing for a stair as per the attached file. I hope the learning to be in video.
Thank you.
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Railing Tool works well on your stairs.  I just tested. Hosted to Treads.  Are you not able to?
Nachricht 3 von 7
als Antwort auf: barthbradley
Please consider my request as a Request for Tutoial On a Sample . But I need it in video to understand all commands used.Thanks
Nachricht 4 von 7
Here's a step-by-step.
In a 3D View:
1. Click on "Railing" (Architecture=>Circulation=>Railing)
2. Click on "Place on Stair/Ramp"
3. Click on "Tread" (on the "Position" Contextual Tab)
4. Select a stair run would want the Railing to host to.
Railing appears!
Nachricht 5 von 7
Hi,My problem is that the floor at the first floor level which connect two flights ( from & to ) first floor the railing at this place does not connect with railing at the flights.How to connect all of them?
Nachricht 6 von 7
So you want one contiguous rail (on right and left side) from the bottom to the top.  It's difficult.  You can get it close though, but if you want seamless perfection, it will require modeling in-place custom components to make the transitions.
Nachricht 7 von 7
hi,
I can apply railing at the two flights ant the landing, but I can not do it for railing at the floor level. how to do that?
