Hello Everyone
I have N/E coordinate Data. Can I create Property Line from it.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Massing and Site > Property Lines > Create by entering distances and bearings.
Thank you very much but It doesn't what I want, I need to create Property line by insert N/E Coordinate of each corner. so I think Revit can't do that. Nevermind, now I already try to use dynamo to slove that. Thank again.
Greetings
did you find the solution?
In revit you can do it using the Project base point (you have to un-hide it using view/graphic override then search for site category > tick the project base point)
once it is shown click on it you will see n/s & e/w values & the elevation .. enter the N/E value of the first point .. draw a circle .. then enter the second point again draw a circle ...do this for all the points because you only one project base point and you have to mark all the points before changing its location.. once you finish start to draw the property line (by sketch) and connect all the circles (centers) ...and that is it you got your plot .. hide the project base point after that.
it is a long process and i rather to find a way to do it in dynamo ..so i wonder if you succeeded? ...cheers
i did pdf-excel-dynamo but i only can make a line along these points, could you teach me how to create property lines with these points?
