Greetings.
Im BIM coordinator in my firm.
I want to fully prepare revit for my colleagues.
In many of our project we use many different wall assemblies and i need more functions in material hierarchy.
Is it possible to create new ones and also rename existing.
*To compare in Archicad each material has power from 1 to 1000 it gives you an option to create hierarchy of materials with 1000 levels. Here max is 6 levels (Screenshot in attachment). And usually you should fix it grafficaly but then materials area doesn't count.
Gelöst! Gehe zur Lösung
Gelöst von blank.... Gehe zur Lösung
